I am using Standard AxdSalesInvoice class to send the Sales Invoice as an XML to Outbound in Ax 4.0 .I am using File system Adapter.
I have written a job which polls the CustInvoiceJourTable and sends the Invoices.When i run this job the record is entered successfully in Queue manager.But when I run the outBound processing batch i am getting below error in the queue manager
Invalid document schema. The following error was returned: The element ‘CustInvoiceJour’ in namespace 'schemas.microsoft.com/…/SalesInvoice’ has invalid child element ‘CustInvoiceTrans’ in namespace 'schemas.microsoft.com/…/SalesInvoice’. List of possible elements expected: ‘FormLetterRemarks’ in namespace 'schemas.microsoft.com/…/SalesInvoice’.
I had a look at the query AXDSalesInvoice–> dataSources–>CustInvoiceJour–>dataSources–>FormLetterRemarks data source.On this data source the Join Mode is Outer join and Relation is 1:1.When i change the relation on this table from 1:1 to 1:n then i am able to successfully send the Sales Invoice to my out bound folder.
Has any one encountered similar error.If yes then what is the appropriate action taken.
Please suggest.
Ismail.
