Hi!
I have a grid on a form. I use autofilter to select some records. After autofiltering I press a button that checks a control in on the selected lines. For that I use this - well known - code:
// CODE STARTS
SG_WordDictionary dictionary, _dictionary;
for(_dictionary = WordDictionary_ds.getFirst(); _dictionary; _dictionary = WordDictionary_ds.getNext())
ttsbegin;
select firstonly forupdate dictionary
where dictionary.RecId == _dictionary.RecId;
dictionary.isAsked = NoYes::Yes;
dictionary.update();
ttscommit;
// CODE ENDS
After that I use the code:
wordDictionary_ds.executeQuery();
It’s almost good, but executeQuery method of the dataSource removes autofiltering.
Anyway executeQuery makes the changes visible but I would like to see only the previously selected records.
Is there a way to get the autofiltering parameters back? In that case I could make a filtering in X++ as I would have a direct control for filtering. Or is there an easier way to accomplish the desired functionality?
Thx
