Hi, a client(3.60) wants a report with an option on the request form that when checked adjusts the bottom margin, is this possible at all? Any help is much appreciated. - Mike
Hi, You can adjust your margines before preview/print as File → Page Setup It will open a window with all the printing options. i hope it will solve the problem. Cheers
You could try using thinner paper!![:)]
