Adjusting Quantity in the Inventory Card without affecting value?
We had a problem with the inventory unit measure on an item rather than kilo it was set up in ton. Already the production orders journal were posted as kilo while the item is seeing it as ton. This was later discovered in April before the inventory close, so we tried to use the reset status to reverse these production orders on the 14th April while the date on the journals were 1st March. We also discovered that it reset the status of the production orders to 14th April instead of 1st March since the reset status method does not give us an option to change the date.
Now it is only the quantity that has been affected because we have not ended the production orders yet and it has not given value to the GL but only the inventory? Please what document can we use to correct the quantity alone for at a zero cost price?
Hi You can use profit and loss journal to adjust the quantity without any cost price
Rajesh
I cannot edit the cost price for quantity which are entered in negative in order to adjust the 14th April date. The quantity in April is positive so I need to reverse it.
If the report as finished was made for 1000 kilos (I guess you are seing in inventory 1000 Tons) I would made a new report as finished for -1000 ‘kilos’ to reverse the quantity, and then I would made the correct report as finished for 1 Ton.
