I am working on a upgrade from 3.70 to 4.00 and when running the Adjust Cost - Item entry process it hangs up and never finishes. Has anyone else run into this problem?
Is this happening in 3.70 before you upgrade, or is this in the 4.00 upgraded database? If the later, then did you successfly run the adjustment in 3.70 before conversion?
It runs fine in 3.70. Talking with MBS this is an issue with the upgrade and they are working on it. Thanks.
Please if you get any news on this, please let me know. I rememebr the disaster this caused from 3.01 to 3.10, I do hope that is not going to happen again.
