Adjust Cost - Item Entries Failed, could not divide by Zero
hai all…
I want to adjust cost - item entries(report 795)…
but it failed,it was said that it couldn’t divide by zero
and after I use debugger I found an error as i bold this one
codeunit 5895 - Inventory Adjustment
CalcCostPerUnit(VAR OutbndValueEntry : Record “Value Entry”;OutbndCostElementBuf : Record “Cost Element Buffer”;ItemLedgEntryQty : Deci
WITH OutbndCostElementBuf DO BEGIN
IF (OutbndValueEntry.“Cost per Unit” = 0) AND (“Remaining Quantity” <> 0) THEN
OutbndValueEntry.“Cost per Unit” := “Actual Cost” / (ItemLedgEntryQty - “Remaining Quantity”);
IF (OutbndValueEntry.“Cost per Unit (ACY)” = 0) AND (“Remaining Quantity” <> 0) THEN
OutbndValueEntry.“Cost per Unit (ACY)” := “Actual Cost (ACY)” / (ItemLedgEntryQty - “Remaining Quantity”);
END;
so, does anyone colud tell me, what should I do?
thanks
Pretty sure there was a hotfix for this back in early version 4, so you could look on partnersource or contact your partner.
hmmmm by the way, I do adjust cost every several months
but this time we had an error divided by zero…
I already convert database to Nav 4 SP 3 (local database)
it’s still error…
It’s an error in adjust cost object and not in client version, so you can even make a technical upgrade to 5.0 you will still get the same error. You must make a object correction.
is it not because because mistake from table?
i thought it was mistaken by table…
but i don’t know what table error
Are you saying that you only run adjust cost once every several months? Why would you not run it daily? I would think you need to run it at least at the end of each accouunting period to have accurate numbers.
I recommend to run that report most often you can to keep precise financial information. Customers prefer to run that report before closing fiscal month.
that’s it…
that’s our biggest problem… our adjusting cost, it’s not always
and now we are preparing for new database, so adjust cost and other mistakes could be solved
thanks for your advice :slight_smile:
