I’m new to the forum, not new to Navision.
To explain why I ask the questios: In the compant I formerly worked for we used the function Adjust Cost - Item Entries / Post to GL a lot to give correct entries on the Item ledger Entries.
The company I currently work for do nothiing like this at all, and the info I get out of teh system is not good enough…I think.
I did some testing (we are now on a newer version (Microsoft Dynamics NAV 2009, Dynamics NAV 6.0), where the menu forms have been customized, I can’t find the things I need.
So far I found the trick to Adjust Cost - Item Entries, but the option “Post to GL” is greyed out. After running the adjustment the ILE shows correct amounts, costs are being pushed down, no changes on the GLE though. How can I get this to work? Is there a seperate function? Is this a license issue?
Thanks for the help in advance, if you need more info, let me know.
