Hi All We are using Navision 3.70 I have problems in running the batch job called Adjust Cost Entries module. When I run this Batch job, either it goes into infinite loop or it goes on accumulating value which result in overflow in decimal value while posting voucher into GL Entry It is happening with one or two items only. If i delete those entries from Item Ledger Entry and Value Entry everything run fine. Any suggestion in this regard will be appricaited Regards PUMMI
You are really using 3.70? You might think this is a stupid question … well, I’m asking because this was an old error in 3.60 (and older) which was fixed with Hotfixes 19 and 22 …
