Hi Team,
We have below requirement:
We need to add new field Customer posting layer (CustSpecificPostingLayer) in GeneralJournalEntry and GeneralJournalAccountEntry table for reporting purpose.
This needs to updated while posting all financial transactions such as sales invoice, purchase invoice, GL journals, fixed asset..etc.
We are using UDE for development purpose as our project using Power platform admin center.
I’ve modified LedgerVoucherObject and LedgerVoucheroTransObject classes and added x++ code. while debugging looks like data coming but it not reflecting in tables at the end. believe something here missing.
Also written coc for insert,update methods of GeneralJournalEntry and GeneralJournalAccountEntry tables but debugger is not hitting.
Really appreciate if someone assist on this. explained requirement in detail below.
Detail explanation as below:
Custom field data mapping: Created new setup map which will have mapping of standard posting layer with customer specific posting layer. find below screenshot for example
We have aleady PostingLayer in GeneralJournalEntry table. While inserting data in same table we need to update the custom field CustSpecificPostingLayer with relevant data based on setup for both GeneralJournalEntry and GeneralJournalAccountEntry tables.
For example: If GeneralJournalEntry table having standard field ‘Posting Layer (CurrentOperationTax is the Table field name)’ has value customer layer1. then custom field ‘CustSpecificPostingLayer’ will have Cus_FR as per the setup form shown above in GeneralJournalEntry table.
Also for same in GeneralJournalAccountEntry table comparing data in GeneralJournalEntry table.
I will really appreciate on this if anyone came across this complex requirement and guide here on this.. Many thanks.
