Adding link between three tables using Query class
Hope you are doing well!
Kindly go through the below given SQL in order to understand my query
Select TabA
Where TabA.col1 == ‘xyz’
Join TabB
Where TabA.col1 == TabB.col1 &&
TabA.col2 != TabB.col2
join TabC
Where TabA.col1 == TabC.col1;
I did not find any way using addlink() method to achieve relation
and
I would appreciate any help you may offer.
Abhinay
Edited:
the where clause for TabC is:
Where TabA.col3 == TabC.col3;
Example:
qbdsTabC = qbdsTabA.addDataSource(tableNum(TabC));
qbdsTabC.addLink(fieldNum(TabA, Col1), fieldNum(TabC, Col1));
You didn’t show your code, so I have no idea what you’re doing there. Ensure yourself that you link TabC to TabA and not to TabB.
Hi Martin,
The code is
qbdsTabB = qbdsTabA.addDataSource(tableNum(TabB));
qbdsTabB.relations(true);
qbdsTabB.addLink(fieldNum(TabA, Col1), fieldNum(TabB, Col1));
//(nocode for TabA.col2 != TabB.col2)
The moment I say
the relation between TabA and TabB vanishes from qbdsTabA.
I don’t see anything wrong. I guess you’re verifying the result by QueryBuildDataSource.toString(), not by running the query. To see both child data sources there, you have to call fetchMode(QueryFetchMode::One2One) on both.
