Adding Grid fields staying as last field
Hi Friends,
I having some fields in a form. When I am adding one more field extra it is staying as the last field. It is not coming from the last position even I am dragged and dropped as center field.
It is in the center in design but when viewing the form that field is staying in last.
can anyone advice on this?
Can anyone advise on this?
Where you are adding field?
Grid or some form group? If possible can you share form design with property and UI as well.
Rohit
Hi Rohit,
Thanks for the reply. I am adding the field in the form grid and I did change any properties and it is display only field.
Could you please share design with property. Because it may be possible that that some datagroup involved where you are trying to add your field.
