I`m having the following problem.
When i right click a form, chose personalise and add new field in it, after i close it and reopen it the new fields a gone.
Shoud i do something aditional so that AX will remember the settings?
It happens in many forms. I`m using AX 2012 R2
Hi Alex,
Normally it doesn’t happens, when you add a new field then a yellow strip should appeared asking you to reopen the form, and the xtra fields which user has added should appeared, if it is not happening in your case, may be its user right issue, do one thing after you add the field, click on save button on the right and enter the user.
Thanks & Regards
Pranav Gupta
Hi Aleksandar,
After adding the fields then save and synchronize the data dictionary once.
Krisheed
Thank you all for the help.
Hi
click on save button after you have added your field before u close.close the personalized form then reopen it.The new field should appear.
