Adding a File Requst to a Textbox on the Report Re
Does anyone know if it is possible to have filename request functionality to a Textbox shown on the request form when processing a report (as the user has the option to export as CSV). At present the user will have to have a knowledge of direcotry structure to be able to use it - it is safe to assume that the end user will have no such knowledge. I’ve tried the suggestion for when using “dataports and the request dissapears”, but this does not work! All I have now are assist edit dots that do nothing! Thanks!
Hi, You can look for example to the report 29 Export Acc. Sched. to Excel
Here it is very clearly explained http://www.mibuso.com/howtoinfo.asp?FileID=4&Type=howto
Solved… Viktora’s idea did the trick. Thanks.
