Added a custom chart, now cant open RTC
Hello all,
I added a custom 2d chart using the chart designer developed: blogs.msdn.com/…/3d-charts-chart-generator-tool-ii.aspx
It was a simple chart of sales invoice header amount broken down by salesperson. Well after adding this RTC role center crashed and said the requested operation is not supported. It repeats this message no matter what company I try to run every time it opens(RTC does not load).
Thanks for any help.
Hi Dan,
Same thing happened to me a while ago [:S]
Using the classic client, look up table 2000000078. It is where Charts are stored. Here is the full removal procedure:
http://blogs.msdn.com/b/nav_developer/archive/2008/08/20/nav-2009-how-to-generate-charts-kpis.aspx
Hope this helps!
Perfect, worked great, thank you.
