Add Range to Query.
I added datasources in the form and joined them through datasource properties and made link type as innerjoin. when i open the form i am getting the right query. But now i would like to add another range to that query. How can i add a range through code to the query that is being prepared automatically through the properties of the datasource.
First add an executeQuery() method on your form datasource then add the following code inside the executeQuery() method before the super();
this.query().datasourceNo(1).addrange(fieldnum(yourTable,YourField)).value(‘yourRangeExpression’);
hope it helps, please verify if it solves your problem
regards,
Thomas
Thank you Thomas it worked.
