Hello,
There is a list of dimensions in DimensionDetails form → EntityList combobox,
( General ledger->Settings->Financial dimensions->new->use values from: combbox )
what is the right way to add tables into that combobox list ?
Hello,
So you want to add another table to existing entities list?
The initial step would be to create view, prefix it with DimAttribute*
look at the cross references for the existing view, you will be able to find what other objects you need to modify.
For detailed instructions, read Setting an entity to be dimensionable in Implementing the Account and Financial Dimensions Framework for Microsoft Dynamics AX 2012 Applications.
