Is it possible to add a field/control in a form from table method ? If Yes, how can I do it ?
Raghavendra.
Raghavendra.
Hi ,
Yes u can,Just drag and drop the method to ur form’s design from table and make sure to set datasource property .
It is not display method. From the form’s init method, a table method is called to set the caption. From that table method, can I add a filed to the ‘overview’ grid in the form or can I enable/disable visibility of form control (string field)?
Raghav.
