Dear All,
in inventory management -->Reports–>on hand–>On hand Inventory report -->wen am running the report -->in go to select button in dialog -->in the query form go to sort tab–>here am trying to add the table and criteria.but this add button is not working.
please give me a solution.
I beleive that is becuase of the OrderMode property of the data source - which is Group by in this case(which will not allow sort by).
yes kranthi,
i checked that property.and i tried to change the property to order by .but still it is not allowing to add.all other reports data source properties are Order by only.
If you want to do sort by you can do in that datasource query…
