I am new to Business Central, and have installed a BC Container on a VM, It has created an admin user for me in Business Central but I would now like to create additional users, however when i go to the users window and click on New it says ‘You cannot add or delete users on this page. Administrators can manage users in the Office 365 admin centre’
I do not have Office 365 admin centre on this VM machine so wanted to know if there was a way to creates users without Office 365?
If you need to make new users in a BC sandbox running on a local machine, then you need to use the New-NavContainerNavUser Powershell CmdLet from navcontainerhelper.
i did use the New-NavContainerNavUser Powershell CmdLet from navcontainerhelper, (see attached file, on the file I entered the container name, tenant name and user name in the parameters section. however when I run this in Powershell I get the following message.
Export-ModuleMember : Object reference not set to an instance of an object.
At line:52 char:1
You should not be running that code directly. It’s part of a module and should be installed and used like that.
Install the NavContainerHelper cmdlets from Powershell with: install-module navcontainerhelper -force
When [mention:b333cd6bdab44ca0937d30924b6e46e4:e9ed411860ed4f2ba0265705b8793d05] updates the module again (happens every few weeks or so), then just run: update-module navcontainerhelper -force
I ran the NavContainerHelper cmdlets from Powershell with: install-module navcontainerhelper -force
and it installed successfully, but I still cannot create a user in the users window in BC, so I am not sure what I am getting wrong or not understanding clearly.
