ADCS
Hi, I’m trying to configure ADCS using NAS and a Navision SQL DB. All the services can be started but not Navision VT100 plugin. I get an error message saying : Service could not be started, either because it’s desabled or because it has no associated devices with it" I know that the plugin uses TCP port 6666, but I have hand-held plugged in the Comm1 port. I can read the data collected by the hand-held with Hyper Terminal, I don’t understand how to associate the hand-held to the VT100 plugin. Could you please help with your experience or with detailed documents on the subject. Thanks
Hello, I think I have seen a hotfix for the ADCS terminal interface. Did you check with Navision? br Anders
