Not a class Function error
display LedgerJournalAccountName AccountName()
return LedgerJournaltable::find(AccountName).AccountName;
thanks for help
thanks for help
HI
Let u try this Code…
if (this.AccountNum)
if (!this.Company)
return this.accountNameFind(this.AccountType, this.AccountNum);
if (xDataArea::exist(this.Company))
changecompany(this.Company)
return “”;
sorry Not Success
table out of range show errors
HI
try this code
return LedgerTable::find(_accountNum).AccountName;
Regards
Syed Abuthahir
ledgerjournalid is incomplited error show And my Table name is LedgerJournalTable
Hi
If you need to find accont name with Help of Account Num but you are using Ledger journalTable so first findout account num from that table the pass that acccont num correcsponding Account type to find …
I hope that u will understand
Regards
Syed abuthahir
sayed sir
my problem is i want print acountnum and acountname in header part
if transition more time in Single Accountnum
So Accountnum print One Time And All Transition in This account print Under this Account
And Account NAme Print One Time
i thing My Problem you will Understand
Example
Account num Accountname
1010 machine
this type ALL TRANSITION UNDER THIS ACOUNTNUM
I HOPE THAT U WILL UNDERSTAND
ACCOUNTNAME NOT SHOW IN FRONT OF FIRST ACCOUNTNUM
I understood .
which datasource you will get Acccount Num?
DATASOURCE
TABLE LEDGERJOURNALTRANS & LEDGERJOURNALTABLE
AND RELATION ACCOUNTNUM==JOURNALNUM
I WILL GET ACCOUNTNUM FROM LEDGERJOURNALTRANS TABLE
AND ACOUNTNAME GET FROM LEDGERJOURNALTABLE
First your relation is wrong
LEDGERJOURNALTABLE .journalNum == LEDGERJOURNALTRANS .journalnum
second you have LEDGERJOURNALTRANS datasource- LEDGERJOURNALTRANS table has accontname simply u can use that methods…
If you are using AX2009
hopefully you will get a output
dear sayed sir
ohhh Sorry my Relation is LEDGERJOURNALTABLE .journalNum == LEDGERJOURNALTRANS .journalnum
and i used AX 2009
And thank u so much for help me
I hope that you will get solution for this issue
if yes Don’t forget to accept as verfified solution.
