I’ve modified the account schedules so that department and project row filters can be set. It works fine in printing and viewing the overview. But if you drill down from the overview I can’t get the row filters to stick. Has anyone done something like this or has any suggestions? Thanks, Lori Helwig[?]
On the columns setup you also have a Department Filter and Project Filter. My guess is that is setting those when drilling down and overwriting yours from the rows. You may want to look at the code and merge yours with the column ones. Out of curiosity why didn’t you use just the column ones? Regards, Cristi Nicola
Did you look at the OnDrillDown Event, for the Details, on the Overview form? This has to be modified as well.
