I’m not the resident programmer, but I was wondering - is it possible to access the SQL tables (created via Enterprise Manager etc.) using Navision Code??? Any starting points would be great…
Thanks in Advance.
Andre Rencontre BCompSci, MCSE HLB Mann Judd Victoria, Australia
Yes. You can access SQL tables and views from Navision. just create exactly the same table definition in Ent.mgr as You do in Navision. Then You import the Navision object to the database answer “Yes” to the question of linking to an existing object. This is described in the pdf on the CD. just be aware that You might get problems with user rights if You use a view that points to another SQL database. Edited by - Lars Westman on 5/20/00 3:59:12 PM
