Salam Alikom ,
Now in our business we use automatic batch reservation , but need to occur batch numbers in any transfer journal transaction , is this can be done ?
as i test to make transfer journal but batch number did not occur whether in transfer journal lines or journal print even after journal be posted
Did you check the inventory transactions? Sometimes, if multiple batches are reserved or something, it won’t show on the form and some of the reports print the data from the form.
batch number occur normal on transactions but we need to occur it on transfer journal page itself
did you try the “view”–>“dimensions” button and select the batch inventor dimension on the form?
select one of the lines, click the inventory–>transactions button and do the same thing again.
