This is the window that shows I have Inventory
See the Report Permission on License Permission.
AS below
Object Type | Object Number | Read Permission | Insert Permission | Modify Permission | Delete Permission | Execute Permission |
Report | 5851 | Yes | Yes | Yes | Yes |
Under which role ID we I have to setup that permission?
It will show just the License permission for that Report. I think you are a SUPER user.
Could anyone still help me with this problem??
@Tony what should I do further??
@subrata
What will show the license permission? what screen you looking at??
Hey David could you please help me in my post about adjust cost. I have been wasting my day on figuring out this problem…
Saroj, please stop posting these reminders. If you need immediate assistance you can open an incident with Microsoft support.
Saroj,
This is what I would recommend you do.
Add a new users, using whatever method you use database or windows.
Add the Role “SUPER” and nothing else to that use.
Just for the hell of it, synchronize the security if you setup gives you that option.
Login with the new user and try to run the report.
If that fails, and you have set the user as I suggested above, and you are saying the license that the server uses is as you have shown us here then you contact either MS or your partner and ask them to cut you a new license file regardless of the fact that it shows you the granule, it could be the config went wonky.
t
