Hello All,
I want to Upgrade Reporting from Microsoft Dynamics NAV version 3.7 to Microsoft Dynamics NAV version 2009 SP1. Please if some One Have Steps to Do That Please Help Me.
Thanks & Regards.
Purvesh Maisuria.
Hello All,
Thanks & Regards.
Purvesh Maisuria.
Hi Purvesh
Are you using devloper toolkit to upgrade or doing manual upgrade?
if you using developer toolkit then follow the below process
Step1: Create a 2009sp1 database to start the developer toolkit application
Step2: Import Devtool.fob into that
Step3: Create 4 database versions in Developer toolkit and named it as follows [3.5Customized,3.5Standard,6.0Standard,6.0Upgraded]
Step4: Export report from 3.5 customized databases and import it into the 3.5Customized version of developer toolkit
Step4: Export the same report from the 3.5Standard Database and import it into 3.5Standard version
Developer toolkit
Step5: Export the same report from 6.0sp1 standard database and import it into the 6.0 standard version of developer tool kit
Step6: perform the merge process [The upgraded object will be displayed in the 6.0 Upgraded version of the developer toolkit]
Step7: Export upgraded object from the developer toolkit and import into your 2009sp1 database
Step8: Realign the controls
Step9: Check the report functionality
Jerome Marshal.J
Hi Jerome Marshal,
Thanks for Replying me & helping for my problem. I must try to go on the path/steps which u show me. Hope you always help me in future. Thanks for This Time & Thanks in advanced for Future problems.
Thanks & Regards.
Purvesh Maisuria.
HI Purvesh
Yu are most welcome
Jerome Marshal.j
