I am writing reports using the Word doc via COM. all works well, but I need to return a value that is being displayed on my form as a method. Its not a value in the db.
How can I reterive that value and print out on my Work doc report?
ciao
ciao
Hello,
Typically in Ax reports, you write a display method in the report.
In your case, it depends on how you are writing this report. Perhaps if you can post some of your codes, some one here might be able to provide an educated solution.
open the method on the table/datasource and you can get the return value
