Hi ,
Actually we are moving from 2009 r2 to 2013 r2, While we are doing webservices requests through xml port using dotnet variables in Code unit , we are facing error.
My question is how the extra tags are adding while running the code like xmlns:p2="xsi, without P2 assigning my code is working fine( I tested By manual coding)
By debugging also it is not showing any specific Schema related error, Can any body help regarding this…
How to remove this tags…
<?xml version="1.0" encoding="UTF-8" standalone="no"?><SOAP-ENV:Envelope xmlns:SOAP-ENV=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:ns1=“urn:Magento” xmlns:ns2=“http://xml.apache.org/xml-soap” xmlns:SOAP-ENC=“http://schemas.xmlsoap.org/soap/encoding/” SOAP-ENV:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”>
SOAP-ENV:Body
da8882738b0af9251f8c710f5c0e7ac1
customapi_address.multiCreate
144
company
xxxxx
street
25 gdfg
region
CA
postcode
92160
country_id
US
telephone
123456/value>
fax
city
San Diego
contactname
xxxx
is_default_billing
1
is_default_shipping
1
145
company
xyzz
street
gfgghdfhg
region
IN
postcode
477056
country_id
US
telephone
124367865
fax
city
Evansville
contactname
nnnn
is_default_billing
1
is_default_shipping
1
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
