When running the Database Test, Test Field relationships between tables, if there any entries in Table 369 using the Windows Login, the test will fail as the TableRelation is User.
If the User table has not been used, you get an error Value not found.
All you can do is to change that to blank I would guess?
Anyone confirm please?
