Hi. I’m trying to develop a new form but I need to have 2 subforms on it. One of them is linked as others subforms using standard NAV methods. For the other one, I have though to use a temp XML Document to handle this. The idea is to filter 1st. subform with a record from the main form, and filter the second form with a record from the 1st. subform.
I found a post wrote by “Tim” form www.advanced-business-systems.com/…/Multiple-Sub-Forms-in-NAV.aspx where he explains how to do this, but when he says about to write code on XMLDoc::OnReadyStateChange() funtion I don’t know how to find that function.
I’m using NAV 5.0 SP1 and I don’t know if that code refers to NAV 9.0 or higher. In that case, do you know how could I solve my problem? Is there any other way to filter the 2nd. subform using records from 1st. subform?
Regards.
