1099 code problem when importing Vendors from Excel
Hi everyone,
I work with Nav. 5. I am trying to import Vendor’s data through Excel.
First, I export blank file from Nav. 5 to Excel, than in Excel I fill it with data. When I try to import it back to Nav. 05 I see a message:
/This message if for C/AL programmers:
The call to member selectSingleNode failed.msxml6.dll returned the following message: Expression must evaluate to node-set.
–>1099<–Code/
The strange thing is that when I am doing it to import Customers I have no problems with importing.
How can I solve this problem?
Thank you in dvance for any help
Hi Skazka,
Did you install msxml6 ? Maybe you repair this pro.
xml file do not allow elements starting with number. One suggestion is to renumber the 1099 to ten99, or remove the field from your file.
Even I am facing the same problem, while importing vendor records in NAV ERP via Excel, mentioned by Skazka…
I renamed the field ‘1099 Code’ as ‘Ten99’ in NAV database. The renamed name doesn’t get reflected in Vendor table i.e table #23 in NAV ERP, and when I tried to import records I got below mentioned error message:
“The 1099 code field on the vendor table does not exists in the SQL Server Table or view.”
Further I tried by deleting ‘1099 code’ column from ‘Vendor’ table in NAV Database. I am still getting the same error message mentioned above.
Renaming/deleting ‘1099 code’ field is not working for me.
Can anyone tell me how to import vendor records in NAV ERP without getting below mentioned error.
–>1099<–Code/
Thanks in advance.
Sujata
