I have enough qty on the location and no reserved qty but when i try to ship the transfer order it pops the ff error.BTW it is NAV 2015
“You have insufficient quantity of Item FG004 on inventory.”
You have to check VerifyInventory function in Table No 32 and put debugger on this function
Maybe you have inventory in Sales Orders ?
Verify if the solution fixed your Problem
Found the problem: the production clerk used the Finished goods location on production order instead of the Production floor location and the developer realized her error and tried correcting the error by just going into the item ledger entry change the location using code and after an investigation he realized he made a mistake and undo the change and then we have changed the item location with reclassification journal then everything works as usual.
thank you guys.
