I’m testing Manufacturing in NAV 5.0. I created a Production order, now when I click on Production Journal I get “You cannot use a Unit of Measure Code because MyLocation is set up with Direcrted Put-away and Pick”. I am stuck. I don’t really want to do Prod. orders in a different location, so where is this error coming from? I registered the pick on the components and would like to now put the finished good away. What am I missing?
Go to your item card → Warehouse tab → Put Away Template code u might have selected Same Unit of Measure match.
and
Check your Item Cards Unit of Measure and Put away Unit of Measure as well.
The Put-Away Template code settings look like this:
The UOM on the item card and on the Put away is the same.
Not sure where to go from here. I don’t want to disable directed putaways on the location card.
Thanks for the help.
