Hi all I have a blackout and need some Help I need to set a Filter from 0101 … 3112 (January till December) The year i will get from a Date field. For Example: In my Date field i have the Value 26.05.04 Now i must set the Filter 01.01.04…31.12.04 IF The Value would be 26.05.02 the Filter must be 01.01.02…31.12.02 Anybody can help?
Use the function DATETODMY to cathch the year. Define to variable Start Date and Finish date And use the year retrieving by the function DATETODMY
Or use WorkDate… (The client itself provides this variable under “Arbeitsdatum” if you are using the swiss client)
SETRANGE(fooField, CALCDATE('<-CY>', dateVar), CALCDATE('<CY>', dateVar));
<-CY>/ can be replaced by -LJ/LJ in the German/Swiss version.
Thanks a lot for your answers
