Hello,
I need to skip na empty tag when i’m exporting a xml file with xmlports. If the tag isempty it should not be on xml file.
The schema that validates the xml file, does not allow empty tags.
How can I do that?
Thank you,
sofia
Hello,
How can I do that?
Thank you,
sofia
perhaps you can test for it and use a currxmlport.Skip command.
http://msdn.microsoft.com/en-us/library/dd339042(v=nav.70).aspx
I already try this and does not work [:(]
Sofia
