XMLport - Header : How can I remove: standalone="no" ??
Hi all
I am making a XMLport to export data from Navision 4.0 SP1 to an FTP-server. Mr. Green
In my header for the output it says:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
I would like to remove the:
standalone=“no”?
Does anyone knows how to do this Question
Regards
Skyggeman
I don’t think you can do that. XML Ports are for simplistic xml files. They have limited functionality and flexibility on purpose, to make them as simple to use as possible. If you want flexibility, then consider using codeunits (MSXML-DOM automation). It may be a little more work to begin with, but it gives you much more flexibility in the longer run. It is better to find out now that there is something you just can’t achieve with xml ports, than finding out later, and you would have to redesign your solution from scratch to use codeunits instead.
Regards
Lars
