XMLPort for importing text files
I have a text file that i need to import into table 83 item journal line
text file contains data in format: itemno;locationcode;unitcost;quantity
so i designed xmlport fot these 4 values
root element text
ItemJournalLine element table
ItemNo element field
LocationCode element field
UnitCost element field
Quantity element field
when i start the xmlport and open txt file i get an error
Item Journal Template Name ‘’ does not exist
Is that happening because of table relation on Journal template name field ? And how can i fix this
you need to specify Template and Batch Name before importing
you can write code on Import::Afterinit Record
Thanks and Regards,
Nandesh
How do i do that ? And how can i check for existing item no and modify it if its exist ?
You can write code and check whether the items are already there on the batch or not
