In dataport I have one field containing amount. In Nav the amount is grouped by three, so after exporting in the text file I have the next: 100˙000, instead of 100000.
Can I set up the format of the amount in order to have only numeric characters?
In Dataport Fields menu there is a Format property, but I don’t know whether it can be used for this and how to use it.
I am closer to the solution, but it is not perfect yet…
I managed to do 0000001000 from an amount of 1000,00. I have in FormatProperty of the dataport item:
<Integer,13><Filler Character,0>
The SourceExpr is the amount.
But if I have the amount of 1000,55, the formatted output is 0000001000 in this case too. I need this output: 0000100055. And if I have the amount of 1000,00, then I need this: 0000100000. So I need the numeric characters without decimal point, with leading zeros to the length 10.
I know that it is because of the Integer datatype in FormatProperty, but I really don’t know what should I write intstead of it.
