XML / XSLT transformation error: Call to member transformNodeToObject failed
I have some code that performs perfectly when running it locally and one a few other clients. But now I installed it on another clients and here I’m getting this error:
Microsoft Dynamics NAV Classic
This message is for C/AL programmers:
The call to member transformNodeToObject failed. msxml3.dll returned the following message:
Not implemented
The code I’m calling is the following:
XSLTDocument2.Data.CREATEINSTREAM(InStream);
CREATE(XSLDOM);
XSLDOM.load(InStream);
CREATE(XMLDOM);
XMLDOM.loadXML('<Dummy/>');
DataFile.CREATETEMPFILE;
TempFileName := DataFile.NAME;
DataFile.CLOSE;
DataFile.CREATE(TempFileName);
DataFile.CREATEOUTSTREAM(OutStream);
XMLDOM.transformNodeToObject(XSLDOM,OutStream);
DataFile.CLOSE;
ERASE(TempFileName);
The error occurs on the XMLDOM.transformNode line.
I have tried with different versions of the XMLDOM document fra version 3.0 to 6.0. The only difference I can really see to my setup and my customers is that I can also select MS XML version 4.0, whereas this option is not possible on the customers environment.
Your client(s) seemingly haven’t run Windows Update for ages, if the latest XML libraries on their systems are v3
Well they are not that much behind. They have MSXML6.0 installed.
Then I can’t understand why the above appeared…
Neither can I, that’s why I’m asking here [:)]
