Hi I am new to nav 2013. On running xml port I am getting error tht root not found in object description.
Pls help.
Pls help.
Welcome to DUG!!!
Following link might help you to understand how to create XMLPORT
http://msdn.microsoft.com/en-in/library/hh169049(v=nav.70).aspx
Hi. I designed the xml port this way only. When I run it ask me to select file and when I select it says element does not found in object description.
Check whether encoding property set to UTF-8 of XMLPORT
Check whether variable description set to correct XMLPORT
Encoding is correct. Variable description. . Where can I check?
Have you copied the XMLPORT from another xmlport ?
If yes then there might be one of the variable which is marking towards old xmlport. Check the fields/variables.
It´s a problem with the UseDefaultnameSpace property. You have to set to No value.
Look in this knowledge Base Article. It was solved on Build
https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;EN-US;2907573
