XML Header - Special Characters
Hello. I’m trying to product the following output: (the values aren’t important…the format is)
<ORIG_AUTH_GUID>TESTBRIC2</ORIG_AUTH_GUID>
165.00
<CARD_ENT_METH>Z</CARD_ENT_METH>
<TRAN_TYPE>CCM1</TRAN_TYPE>
<USER_DATA_1>10008930</USER_DATA_1>
<USER_DATA_2>360 VT Tech Ltd</USER_DATA_2>
<INVOICE_NBR>0102IN000007561</INVOICE_NBR>
<CURRENCY_CODE>978</CURRENCY_CODE>
<TRAN_NBR>1</TRAN_NBR>
The problem is in the and tag part...I cannot get it to allow special characters such as the = or quotes between the < and >... I get:
ERROR: The ‘=’ character, hexadecimal value 0x3D, cannot be included in a name.
Here’s my code:
//concatenate line in XML
fileStr =
“file_id=’”+BatchLogTable.fileid+"’ file_total_amount=’"+num2str(myView.AmountCur,0,2,1,0)+"’ file_tran_count=’"+num2str(myView.RecId,0,0,1,0)+"’";
batchStr =
“batch_id=’”+currDateStr+"‘cust_nbr=’"+dialogCustNum.value()+"‘merch_nbr=’"+dialogMerchNum.value()+"‘dba_nbr=’"+dialogDBANum.value()+"‘terminal_nbr=’"+dialogTermNum.value()+"‘batch_total_amount=’"+num2str(myView.AmountCur,0,2,1,0)+"‘batch_tran_count=’"+num2str(myView.RecId,0,0,1,0)+"’";
//start creation of XML
doc = XmlDocument::newBlank();
nodeFile = doc.createElement(fileStr
doc.appendChild(nodeFile);
nodeBatch = doc.createElement(batchStr);
nodeFile.appendChild(nodeBatch);
Everything after this works, so I didn’t include it. If I remove the single quotes and equal signs from the fileStr and batchStr values, I don’t get the error, but I need those so they can be read on the other end.
Any ideas?
thanks!
It’s because createElement() expects a name of an element, therefore the whole string you provided is interpreted as element’s name and characters as ‘=’ are not allowed there. But the name is wrong. The name is “FILE”, not *"*FILE file_id=“20140318A” file_total_amount=“1945.00” file_tran_count=“10” (for example). Use setAttribute() to add attributes to an element.
Thanks for your help…I actually came to same conclusion after posting this. This was the first time I dealt with trying to create an XML, so I had trouble with my syntax when trying to use the setAttribute(), but I finally got it figured out. I was over-thinking it.
Here’s a simplified sample of my code for anyone else looking for same solution, since there’s not a lot of examples I found out there…
Create a new class and create this as the main method:
public static void main(Args _args)
//declare variables
XmlDocument doc;
XmlElement nodeFile;
XmlElement nodeBatch;
XmlElement nodeTable;
XmlElement nodeAccount;
XmlElement nodeAmount;
str myFileName;
CustTransView myView;
date currDate;
//define file path and name
#define.filename(@’\serverName\folder\FileName’)
//data used for my example
currDate = systemDateGet();
select sum(AmountCur),count(recid) from myView where myView.TransDate == currDate;
myFileName = ‘Sample.xml’;
//FILE Node
nodeFile = doc.createElement(‘File’);
nodeFile.setAttribute(‘file_id’,myFileName);
//will display Total AmountCur and Total # of records from myView in node (from previous sql select)
nodeFile.setAttribute(‘file_total_amount’,num2str(myView.AmountCur,0,2,1,0));
nodeFile.setAttribute(‘file_tran_count’,num2str(myView.RecId,0,0,1,0));
//BATCH Node
nodeBatch = doc.createElement(‘Batch’);
//uses date as the batch id to display in node
nodeBatch.setAttribute(‘batch_id’,date2str(currDate,321,2,0,2,0,4,DateFlags::None));
//DETAIL Node
While select myView where myView.TransDate == currDate
//display Account and Amount for each record in the node
nodeTable = doc.createElement(“DETAIL”);
nodeBatch.appendChild(nodeTable);
nodeAccount = doc.createElement(“Account_Num”);
nodeAccount.appendChild(doc.createTextNode(myView.accountNum));
nodeTable.appendChild(nodeAccount);
nodeAmount = doc.createElement(“AMOUNT”);
nodeAmount.appendChild(doc.createTextNode(num2str(myView.AmountCur,0,2,1,0)));
nodeTable.appendChild(nodeAmount);
//save XML to path
doc.save(#filename);
//display completion message
info(strFmt(“File %1 created.”, #filename));
