www.mynavision.net
Does anybody know what has happened to www.mynavision.net? I have tried to enter it for some time now - with no luck…
It is working fine. But be sure you use the domain www.mynavision.net, and not the IP address. It has changed recently. And be sure you are not behind a firewall. The site uses port 38001. If you are, you can use www.anonymizer.com or www.cotse.com, to access the site.
Just a comment on posting here. If you write a full or partly URL (with or without http://) then this is automatically changed to a link in the text when posted. This way writting " www.mynavision.net, " will not work. Writting " www.navision.net " will work. Simply due to the comma. So always insert a space after the link/url. Best regards, Erik P. Ernst, webmaster Navision Online User Group
