Wrong UTCDateTime Value is fetched
Let me take an example.
There is one UTCDateTime field in EmplTable “CreatedDateTime”.
The actual value of that field is “20/05/2012 11:30:00 am”.
When i select that value through job code,I am getting that valus as “20/05/2012 6:30:00 pm”
I want to fetch the actual value as it is in table.So Please help me to solve this problem.
Actual Value in Table:“20/05/2012 11:30:00 am”
Fetched Value From Table: “20/05/2012 6:30:00 pm”
It is fetched the value adding 7 to theactual datetime value.
I need the actual table value “20/05/2012 11:30:00 am”.
Please help me.
Thanks & Regards,
Britto John Baskar.A
How are you fetching the value? Please can you post your code?
Hi Harish,
I fetched using select query
select EmplTable where EmplTable .EmplId==“1000”;
info(strfmt("%1",EmplTable .CreatedDateTime));
Thanks…
