Wrong SN loaded in item ledger
Hi, I have loaded the wrong SN in the item ledger entry using an item journal. Is is ok to just change the SN in the item ledger entry table? Are there any other table that are affected? I know that the best way is to do a negative adjustment and repost again but its quite a lot so I am just thinking of creating a script to correct the table. Regards, Alex
yes it’s ok. I’ve done it. Make sure they haven’t been applied to any other entries. If you are using warehouse management for the location, you have to also change it in warehouse entry table.
You could use a reclassification journal.
