Ive made a mistake, posting af journal with a wrong date on the journal lines. I have withdrawn all the wrong postings.
Can i somehow get up the journal lines again so i can repost it with the correct date? or maybe copy posted lines into a journal? Or do i have to manually type the lines again in the jorunal?
Hi! There is no copy functionality but as you are on Nav 2013 you could create the journal from the postings made in excel and then copy into a general journal.
Have you used this functionality at all? If not I can send some brief instructions.
Or probably just as quick to manually type in again.
Yes you can copy an area in Excel (number of columns, number of rows) to Dynamics Nav 2013 / 2015 as long as column structure / order the same as the journal you are posting into.
Ever seen this done? If not let me know and I will create some screen shots and a link to our web page where the screen shots are.
