I am doing upgrade project from AX 2009 to AX 2012 R3. Data Upgrade is completed successfully. But when i try to open the forms which contains financial dimension tab like Payment Journals, General Journal etc., its throw me ‘Wrong Parameter Specified’.
Thanks in Advance,
Aravindraj.
You’ll have to do some debugging to identify the cause. It’s impossible to say from your description which method threw the error and why.
Yes i done debugging from LedgerJournalTable Form init() method by open General Journal Form.
In that 100 th Line
dimensionDefaultingController = DimensionDefaultingController::constructInTabWithValues(false, true, financialsDimensionsEnabled, 0, this, tabFinancialDimensions, “@SYS138491”);
@SYS138491 label as ‘Financial Dimensions’.
But In class DimensionDefaultingController - constructInTabWithValues () method
The 7 th parameter str _introGroupLabel is enetered as ’ ’ empty
if ((_formRun == null) ||(_tabPageControlContainer == null) || (_introGroupLabel == ‘’) || (_company == ‘’))
throw error(Error::missingParameter(null));
Is any Parameter i need to set regarding this error?
