on the first line: warehouse B ------- Production, if i do: inquiries > explosion, then it shows the incorrect item name and number
on the second line: warehouse A -------- Transfer if i do: inquiries > explosion then it shows the correct item name and number
This item is supposed to be transfer from B to A and for the work order to be cut, but it does not show the item name and numbe correctly on line B when do and explosion. any idea what’s wrong with this ? TIA
Thank you. i went in and cut the planned transfer order then it shows the right item and what needs to buy for that production order in net requirements. i am not sure why did it show a different planned transfer order, item number before cutting that planned transfer order. it should not, but it did, any idea why did it happen that way ?
