please excuse my bad english. I am Steven from Austria…
I would like to implement a column in my financial statement, type
“calculation”.
Inside this column i would like to calculate the ratio from two columns in
percent. Inside the dynamics help i found a formula like this “#1/#2 %”…
But that does not work!!! Immediately after I insert this formula I get an
Infolog message "Warning:
There are syntactic errors in the expression "…
Any Idea?
Thank’s a bomb!
Steven
Hi Steven,
Have you tried replacing the % with *100 ?
I do not think that the system likes %
It worked fine for me
Guillaume
Hi Guillaume,
thanks for the reply. I also replaced the % with *100.
But this example shows a problem:
#1 = 100
#2 = 0
(#1/#2) * 100
would be a DIV/0… it happens sometimes that #2 = 0…
so you get hundrets of infolog messages “DIV/0”
Whats your experience with the financial statements in Dynamics V4? I have a really big performance problem!!! Sometimes a report takes 30 minutes and sometimes it only needs a few seconds??? Many times the report is not generated… you have to close your AX client…
I tried it with reports with only one AccountNumber and a depth of 1 Layer. It doesn’t make any difference if I use a small statement (1 layer) or a big
one with 8 layers and 200 AccountNumbers.
Any Idea?
Thanks a bomb for your help!
Steven
Hi Steven,
My experience with Axapta is very limited as we only started using it this January.
I have exactly the same problem as you regarding the DIV/0 and I have not found a way to get around it yet.
Do you have a secondary focus in your reports?
I have not been able to run any reports if I added a secondary focus so I tend to stick to one focus at a time.
If I do not have too many DIV/0, my reports take a couple of minutes to run.
If there are too many DIV/0, it can take up to 10mn to run and then 5 more to display the error messages.
Sorry I can not help you more
Guillaume
Hi Guillaume,
sounds not good… I do not need a secondary focus for my reports.I only use accounts and no dimensions such as departments or cost centres.
Have you any contact to Microsoft… I think we both are not alone with this problem!? Every accounts department needs those reports…
Regarding the DIV/0, Microsoft instructed me to remove the help text about the % sign as solution… MS closed the ticket… Funny, isn’t it?
Anyway, I need a solution soon… otherwise the guys from the accounts department will kill me…
Many thanks for your answer and good luck!
I’m keeping you informed!
Steven
