Am working on Hospital management system using Nav2017 development environment and run to display in role tailor center. My problem is coding, in my design i have option, text, and code as data type. I need your helps with solid materials and guide. Thanks.
Could you be a bit more specific? What is your questions?
I already have List page of this page
Firstly to set up No. series for the No. of the page and appear once i click new from the page.
There should be activate sign in the name, also to to be able to save (insert)
I also need materials like videos and pdf format that i can use to achieve my goals
Ayinde01,
Did you tried taking help from the Standard NAV codes being used in different objects??
Ayinde01,
Ayinde01,
Try to check how standard object works and how it is updating records in tables
I am trying to download e-book for implementing microsoft dynamics nav pdf but it was not free. Please send it to email if you have ibrahimwasiu2005@yahoo.com or wasiu.laplace@gmail.com. Thanks
Check MSDN for more help and check for videos for how NAV works
