Dear friends
how can i write this query (condition) in Navision Select Distinct(“Item No.”,“Lot No.”,“Expiration Date”) from "Warehouse Entry"
Dear friends
Hi Akhilesh,
that’s a challenge in NAV, because we have no select distinct. What you need is:
a proper key on the warehouse entries, consisting of “Item No.”,“Lot No.”,“Expiration Date” - these must be the first thre members of the key.
a special loop in C/AL, like in report 94:
with whseentry do begin
// set the key
if find(’-’) then begin
repeat
setrange(“Item No.”, “Item No.”);
setrange(“Lot No.”,“Lot No.”);
setrange(“Expiration Date”,“Expiration Date”);
//here you can copy to another table, or do calculations on those entries
find(’+’);
setrange(“Item No.”);
setrange(“Lot No.”);
setrange(“Expiration Date”);
until whseentry.next = 0
end;
This loop touches one record for the selected fields, but only (!) if the key is right.
with best regards
Jens
You can always create a dedicated view on SQL to achive your result.
This is the logic
I forgot to use this option
Thanks Jens.
I have already written one code for that but its taking around 6 min for 15 lacks warehouse entries …
Your code its reduced to 1.5 min … nice logic Keep it
regards
Akhilesh
Thank U
i tried it for G/L entry.pos order no. but it is not working.
it just take only last value.
If you’re on NAV 2013 or later, it’s simpler to do this. Use a basic query object.
There’s a NAV design pattern for this: SELECT DISTINCT with Queries.
